CHRIS
- ESSEX MATE!
Most people only post when wanting answers or giving advice but I wanted to report back on my first finished room of my 200 year old timber framed cottage in Essex.
I have stripped off tonnes of 1966 plaster board (I know this date as I met the bloke who did it) and cement based skim plaster from the Earth - chalk and hair lime plaster from the original part of the house, I then used a Fine chalk, fine local sand and lime putty mix and filled the joints of walls and ceilings and for any substantial holes where the pink skim had pulled off the wall back to the infill brick work I used 2 x 3-1 local shape sand, goat hair and putty mix coats and the a final skim of the finish stuff.
I let this go of for a week and the started a lime wash of plain white on the ceiling, I watered the first 2 coats 50 - 50 with water and sprayed the surface down good and proper before use, waited a few days then 2 coats of full strength limewash, I then did the same with an "Old white" (slightly grey) for the walls and it is amazing, the finish is beyond good. My wife is over the moon about it and I have earned 1000 brownie points!!! so all is good.
I still have to panel an exposed back of a chimney breast as all the tar etc is leaking out and I will have to wait to find some nice juicy cow pats until later to stop this!! and the finaly get some skirting (any good tips on fixing to lime plaster walls? or a few nails ok?)
I am now hooked on limewash and cant wait to do the rest of the finished walls - infact I may go into buisness doing this as you cant find anyone around here who knows about doing this, all they do is PVA and emulsion over everything.
