I'm experimenting with colouring limewash, so thought I'd share the results, just in case anyone else is contemplating having a go, or can offer some hard-won advice.
This is an 'honest' experiment, in that I'll post the results of each coat (just 3), rather than waiting to see if it turns out alright!
I've already repaired the plaster (wobbly, not levelled with screeds) and applied 3 coats of basic limewash. All made up with lime putty and water 1:2, which is much cheaper than buying ready made stuff.
The intention is to get the colour to complement the stone of the fireplace, just a shade or two lighter. The pigment used was Raw Umber and Raw Sienna, which we mixed with water, then left to stand for a couple of days before mixing with limewash. We just used 150ml of the umber, 50ml of the sienna and made 12 litres of coloured limewash.
After the first colour coat, the effect is somewhat patchy, a bit like a cowshed... interesting anyway ...
It's freshly coated, so will lighten considerably as it dries. It is always a revelation each time you go in the room and see how the effect has changed.
The next coat will follow in a few days..
Ian
Ian
