CymruTom
- West Kirby
Hello folks
Wevre in a victorian semi with lime internal walls. We've just had the house rewired and now need to plaster the cable channels (and patch up some other bits of damaged wall).
I've come across a lime based product called Limelite and wondered if anyone has experience of using this... And if so do you recommend it? Is it better to use this vs standard gypsum plaster for this type of gap filling job or does it not massively matter (particularly for internal walls?)
Also, our electrician has done some basic plastering using gypsum to fix switches and sockets to the wall in some places... Is it worth considering digging this out and redoing with lime based, or not worth the bother. This is just small amounts of plaster around the fittings and mostly on internal walls - but not exclusively. (We should have thought of this earlier obviously).
Any thoughts welcome
Tom
Tom
