Hi, I have to admit to being confused about limecrete and its theory. I'm considering spending quite a bit of cash to have a chunk put into two rooms and a pantry in my house. My underlying confusion about the concept has been brought to a head as the existing concrete floor is dug out of one room and the limeash from another.
To start with there is a huge difference of opinion between two of the major suppliers of materials; one says the surface needs to be breathable as it transmits moisture to the surface and the other says that it does not and any impermeable covering can be used. If it is the first then I can understand the concept and how it might be better than a concrete floor with DPM. If the latter then surely by stopping moisture rising at a depth of 300mm or so it is no different at all from a concrete and DPM system, any moisture sitting in the area occupied by the floor will still only be able to exit at the edges. Is the supplementary theory that is just sits there with limcrete/glapor and somehow tracks along the plastic membrane in concrete?
The main reason I ask is that in one of the rooms, excavation of the two layers of concrete and DPM has reached a layer of sub floor with preserved sleeper walls from an original suspended floor with infill between them of very damp sand. As I wanted a wooden floor (parquet) I'm now asking myself if it isn't better in this room to re-instate it along with insulation and underfloor ventilation. I'd like to have parquet and I've no idea if this will work on limecrete or if I'd be better of with plywood directly onto joists with insulation below (actually I think I do know the answer to that;-))
Any thoughts on limecrete theory or experience with laying parquet on it would be gratefully received.
