El Greyo
- Oxfordshire
Hello all
In our small 17th century timber and brick cottage, we have concrete floors downstairs. Having worked on the ground levels outside and installed a french drain, we don't have a (touch wood) damp problem in the walls so we don't have an absolute urgent requirement to put in limecrete to cure a damp problem (although there is a mysterious dampish patch in the centre of the floor - not sure of source at moment). But we're working on the living room and I'm trying to improve the insulation all round and this includes a warmer floor. The concrete slab is very cold in winter but we haven't tried insulation on top of it yet to see how much difference that would make. The ceiling is low so I don't want to add too much that would raise the floor level.
So my thoughts are that the best approach is to remove concrete, dig down, put in leca insulation and limecrete slab on top. But it's a big job with lots of disturbance so I'd probably get an experienced firm to do it. As damp is not a serious problem I would think NHL 5.0 is appropriate.
My questions are:
How long does it take for a limecrete slab to set so that a) we can walk on it and carry on works to walls, ceiling, windows etc and b) until it is ready to use as a living room again? I know that it depends on environmental conditions but rough figures would be helpful.
Can anyone think of any other alternatives? T'other half has suggested battens and floorboards but she is quite a bit smaller than me and won't be bumping her head.
Also - anyone know of an Oxfordshire based building firm that will install a limecrete floor? And know what they are doing - because I don't.
Thanks very much
El Greyo
My questions are:
Thanks very much
El Greyo
