DaveBrigg
- North Lincs
There have been lots of posts about limecrete floors at ground level, but it is quite possible to have them upstairs too. For some reason lost in time, part of the limecrete floor in what is now the bathroom is exposed below from the kitchen, revealing its construction.
1. Limecrete can be laid directly on top of floorboards
2. If for some reason there are no floorboards, rest a loosely spaced layer of laths between the joists.
3. You can, if you wish, add a few more laths across the first layer, but this seems to be optional.
4. Cover the whole thing with hay. If you can time the work for the autumn so much the better.
5. Pour the limecrete directly on top.
6. Don't forget to warn the person cooking below before you empty your barrow of lime onto the hay (OK, I made this one up, but there are still occasional bits dropping down a few hundred years later)
