biffvernon
- Lincolnshire
Biff
As someone who is more used to brick and timber I do not claim to be an expert on stone. My understanding is that if lime in a very watery solution is applied the water evaporates leaving particles of lime to fill voids, etc - hence consolidating the stone. This is of course a very simplified (simplistic!) view, but generally a non scientific explanation of how lime watering should work. However, I have been told by colleagues that in their experience it does little to assist in the slowing down of degaradation. Not sure why and it would be useful to have more information and scientific backing or counter-argument to the use of lime watering. A few years ago I suggested lime watering be considered for some fragile carved stone and was told that the powers that be do not consider it a suitable method because it had been used on this particular item before and had done little or nothing to help prevent deterioration. I suspect this could make an interesting separate thread whereby others share their knowledge and experience of this method.
Penners
Big Guns can do a lot of damage if used too frequently or indiscriminently!!
And so to a separate thread.
I think the clue may lie in your phrase 'water evaporates leaving particles of lime'. If you mix hydrated lime with water you mostly have a suspension of lime particles (calcium hydroxide) and when the water evaporates these particles will slowly carbonate to form particles of calcium carbonate which may, or may not, be bonded to a greater or lesser extent to the stone.
When the stone is watered with lime water we have a different situation. Most of the lime is in solution rather than in suspension. As the water dries the calcium has to come out of solution, forming crystals which may, or may not, be bonded to a greater or lesser extent to the stone. I suspect the bonding in this case will be much stronger. But, like I said, it's very complex; it only takes a small proportion of other ions such as magnesium to alter the chemistry, and thence the physical properties, significantly, and there has not been a great deal of scientific work done on it.
