tobydog
- South Suffolk
Potential dumb question alert. I recently bought 3 tubs of lime putty (25kg each) from Anglia Lime. Way more than I need but as it lasts forever when looked after properly, matures with age, and was relatively cheap at £14 per tub, I stocked up. The tubs have settled well and have about an 1" of water above the putty. When I use the putty I will drain off the excess water and only remove as much putty as I need for each batch which will not be much. My dumb question is, how much denser is the putty at the top compared to the bottom?. I know I can poke a cane in but that's not very accurate and I could end up with a sloppy mix. Once I've removed the excess water, should I stir the whole tub before taking out just what I need or is scooping off the top okay?
I've been using NHL to date but would prefer a more breathable / softer mix for what's coming up.
