Hi there. I had some quite extensive work done on my house 4-5 years ago. Part of this involved re-building some brick plinths using lime mortar after taking up a concrete floor and replacing with a suspended wood floor. Concrete had been causing damp issues. Now the mortar joints are failing - basically below a certain level the lime mortar is like sand (if I wanted to, I could tooth it all out with my finger a pull out the bricks). This work was done by a local line specialist.
I'm looking for advice on what may have gone wrong. It was a very hot summer when the work was done, and the builder never kept the work damp. I suspect that plus a poor mix led to poor carbonation and now the mortar is breaking down.
My second question is what should I do to remedy this and what lime should be used?
I've attached some photos of the inside and outside of one of the effected walls. Most (but not all) of the impacted areas are below the slate DPC visible in the photos, and it is far worse on the inside of the house.
Any advice would be really appreciated.
Thank you
Thank you
