quad121
- Workington
Hi, I have moved into a Victorian terrace which in the front room on the external wall there was damp on removing the concrete to bare brick there was a strong smell of damp also there was a very hard black ' concrete' like substance which when chipping off had sparks coming from it. Any way on the lower 12 inch or so of the wall the paint is bubbling in places on scraping this off there are white deposits which I'm guessing is salt? I Have started to re plaster with a lime sand mix on the internal wall. Would this sought out the external salt deposits? Also noticed on part of the newly plastered wall there is a white patch which I'm guessing is salt. Will this stop showing once the plaster has dried?
Many thanks for any help you can help with
Kind Regards
Paul.
Kind Regards
Paul.
