Andys
- At the seaside in Hampshire
Hi All, Interestingly this isn't an old map I found, I've been rescuing a disintegrat-ey daub panel. Stainless screws (into the staves) and Big Washers seem to have stabilised it quite well and I've been keeping it damp and patching with new daub, which is wonderful stuff to use by the way.
I hope to keep the original lime plaster coating where it hasn't already been lost, it's only about 3mm thick and well haired, pretty tough and flexible but not too well stuck in places.
Any suggestions on the plaster mix for patching? - the old plaster doesn't seem to have any aggregate in it larger than dust.
I normally use a 2:1 sand: Lime Putty mix for general patching and repointing but for this thickness a fine sand+ lime putty + hair mix would seem to be in order, or maybe no sand at all(??) If the lime was originally slaked and the plaster mixed on site I'm wondering if there might have been enough misc roughage present to allow the plasterer to get away with just adding plenty of hair and hence putting it on thinly so it didn't crack up.
I don't really want to plaster overall and cover up the old plaster layer so I I thought I might recess the washers by careful use of a hole cutter, by hand maybe and fair over the hole with the haired plaster.
Any thoughts anyone?
Andy
Oh yes, this is how it looked earlier in the proceedings
Andy
