malcolm
& Clementine the cat
- Bedfordshire
I'm nearly ready to start plastering in the kitchen onto a solid brick wall. Apart from a little repair in the attic this will be the first plastering I will have attempted inside. I have a tonne of plastering washed sharp sand (ordered in error) and am keen to use some of that up in my plastering mix. It doesn't have much fine stuff but seems to work in a 2:1 mix.
The kitchen needs to be insulated for building regs and I'm thinking straighten the wall with lime plaster, stick on wood fibre board insulation (or is it wood wool), more lime plaster on top for the final finish.
What do you use for lime plaster mixes indoors? Or could you direct me to more info - it must have been discussed at length on here but I can't find anything as plaster is too common a word and the search box refuses to search for it.
