Gervase said:a coarse wife pan scourer
On advise from my plastering mate, I used the following method on mine though this was for a wall with modern plaster rather than lime:Spike said:The conduits are full width to the chases and so the only area for the new plaster to bond to would be the edges of the plaster each side (assuming it will not bond to the plastic).
Penners knows not of coarse wives - they are beyond his ken.Moo said:Gervase said:a coarse wife pan scourer
Cue Penners.......
Absolutely agree. The capping also stops any slightly springy lengths of naked cable bouncing back after trowelling, and cracking your plaster.Gervase said:The capping gives your (or your sparks) slightly more leeway to work on the tails where they emerge from the plaster without risking pulling off a scab of plaster. Having done both capped and naked (and had plaster crack and scab with the latter), I always now use the plastic covering. It also stops your trowel snagging the head of a clip nail or a flopping bit of cable, which is extremely annoying.
I can't help feeling that this would have been considered when the wiring regs were written. There can be few houses that have a consistent environment for cabling. Cables run from free air into plaster, out again, into conduit and so on. It's the norm.Flyfisher said:is there a need to de-rate the cable because it is no longer in free air?
