dandrew
At the risk of being dragged over hot coals I'll post the following question:
1850-ish sandstone villa, frontage faces south
Persistent leaking from portico roof, this has been re-leaded in last 3 years (apparently capably done, but do not have the expertise to tell)
Internal paint finishes either side of the front door show water damage at cornice level. Hasten to add that they are modern emulsions on gypsum plaster - lime plaster hacked off by a 'developer' 5 or so years ago. Exterior stone above door was painted with Sandtex or some other masonary paint. This had deteriorated so I finished it off by hand stripping. Now the paint is off the exposed stone seems dry, though the pointing is defective in places. Will repoint the gaps but wonder whether lime is best in this situation. Whole house has been repointed at least twice with cement mortar (probably 1960's and then again by developer), and all the lime plaster stripped off and replaced with gypsum. In this situation I have no inclination to re-do all of the pointing and then re-plaster the whole of the house, therefore will it really make any difference if I do this small bit of re-pointing with lime when the house has since stopped breathing ? I want to cure the leaking portico and the re-pointing is just one job that may help, though I have my doubts.
What do you folks think ?
David
David
