davidt3449
Hi all
We’ve just bought a Grade 2 listed end terrace which needs a bit of renovation and I’m keen to do things once and do them right. I’ve been trawling the internet for weeks, had a structural survey and an independent damp survey, and I’m still unsure what to do for the best, so would really appreciate any advice or opinions anyone has to offer.
It’s a solid, stone built mid Victorian house which apart from very slight penetrating damp on a couple of through stones and patches under the sash windows, appears to be pretty damp free.
It was ‘renovated’ by the council around 30 years ago and is now a mixture of original lime plaster and gypsum. My plan was to knock off any plaster that’s blown or showing signs of damp and replace with lime. Where the gypsum looks ok, I was planning to leave it.
However, my damp survey has come back saying, don’t bother with a DPC (good, I wasn’t going to), install some air bricks in the sub floor void (sounds reasonable), but put up dry wall on external walls with a waterproof membrane to stop condensation on the inside of the stone. This seems like a modern solution that is asking for trouble? A soon as something fails, you’re surely going to get issues with the stone walls not breathing? I asked if lime plaster was a good alternative but was told that if I’m installing central heating, the lime offers little thermal insulation and the wet air would condense against the cold external walls, leading to a mouldy, cold house.
Does this sound right? I certainly don’t want to compromise the integrity of a building that’s been standing for 150 years, but I’ve got to be practical as well.
Many Thanks
David
Many Thanks
David
