Hi guys! Really hoping someone’s able to help. We have an 1850’s Yorkshire stone terraced cottage.
We’ve recently had our internal lounge (facing external wall) and fireplace wall removed of gypsum. It’s about 20sqm. We were quoted £3k to have it plastered and the guy said we’d be better off doing it ourselves. Figuring we would not be able to do a good enough job, we went with a recommended plasterer who had used limelite before and was up for a challenge. The place we got the lime said they were happy to advise on application and the plasterer was happy to operate in this way.
We were really happy with the finish. Except the corners. The guy was also really disappointed. We were mostly disappointed with the guy advising as clearly the way corners should have been handled should have been explained from the base layer. The plasterer tried to make them a point, which clearly doesn’t work in lime. We’ve had bits chip off and it just doesn’t look good. We don’t need it 100% but we do need to do something.
We have started to test how we might fix this. We have sanded down a corner that will be covered by curtain, plan to lime plaster over then possibly sand back to make sure the wall and fix merge. Will this work?! Any better ideas?! There are only 2 corners that will actually be visible so we have plenty of practice opportunity. Just not quite sure if it’s just going to look like we slapped it on and it will just peel off?!
It’s a risk we look to save £2k of money we don’t have - so no regrets. But trying to find the best fix from this point. On the up side it appears our damp issues are resolved :mrgreen:
Pic 1 is the corner finish
Pic 2 is the sanded down corner
Pic 3 is one :shock: of the chips
So many thanks for any help or advice that can be offered!
