Having personally watch virtually every last little bit of work going on at my cottage for the last 3 months, I had to leave the builders to themselves for 2 days last week. During this time they repointed the chimney stack - it desperately needed doing. We had specified lime mortar, which the builders said they were happy with. I trusted them on the matter, as so far they have structurally repaired the very fragile roof using oak and traditional methods, laid a limecrete floor and happily worked with our ground source heat pump. They seemed happy to accept our reasons and methods, even if they weren't sure why they were doing it.
So when we got back from our 2 days away, we looked at the chimney pointing and were not entirely sure it looked like lime mortarbut it didn't look like cement based mortar either, but being on the ground it was difficult to tell what it was. I asked the builders today what they had used, and they said 'lime mortar.' Oh good, I said. 'Yep - we used 6 parts sand, 2 parts lime, and one part cement just to give it a little bit of strength. It was too soft without it.' :roll: Aaargh!
So, having re-educated them about what 'absolutely no cement' means, what I was wondering is whether that amount of cement in the mortar mix will be a big problem? I know the mortar must be softer than the bricks, but is the bit of cement in this mortar going to make the mortar too hard, yet not tough enough for the job - worst of both worlds, as it were? I don't really want to have to get the builders to re-erect the scaffolding, chip out the mortar they have just put in and re-do it, if it is not really necessary. I realise in an ideal world they would never have done this to start with, but the builders have been otherwise good and I have no wish to get their backs up. It was not a large area, and the rest of the house will be repaired using proper lime mortar.
