88v8
- Glorious Gloucs
Well, not quite underpinning...
An elm wall plate about 12' long and 6"h x 4"w, is damp/soft because the wall below it has no means of breathing. I plan to rectify this by taking out the top course of flat stone below and inserting weathered coping to provide runoff, and at the same time slip in a couple of layers of slate to isolate the beam from the wall beneath. I am conscious that this is akin to underpinning and has to be done sectionwise, probably in 18" runs.
So, question: how long should each 18" run be left to cure before it will bear load and permit removal of the adjacent section.
I am employing a good specialist stonemason, who will be using NHL3.5 and sharp sand.
I just want to check that he doesn't get too carried away in terms of speed.
Ivor
Ivor
