Nigel Watts
- London N7
My builder hired a lime plasterer last year to do a number of repairs, including replacing a small length of external moulding on my stucco facade. Part of this has now come loose an I have had to remove it. The problem was not with the final layer which formed the moulding, which was hard enough, but with the layer below which was very soft and damp - hardly carbonated in parts - and which had probably expanded in the cold weather, causing the hard outer surface to crack ( a similar thing has happened to the render on my front garden wall, the outer surface of which is hard but the inner layer is still soft and has expanded, causing the whole thing to crack). I suspect the problem was either that the lime mix was faulty or that the lower layers were not given sufficient time to carbonate before the final layer was applied.
A few weeks before the cold snap I strated to repair the moulding myself and put up a first layer of lime which was about 3 parts sand to one of lime putty. When preparing to add a second layer yesterday I noticed that this was still very soft and weak so I removed it. It should have had time to carbonate before the very cold weather so I am wondering if the problem was that it got too wet.
Is the answer to use a hydraulic lime?
I have now put up a mix of about two parts sand, one part pozzolan, one part lime putty. This should in theory create a hydraulic lime which should be quicker setting, harder and capable of setting when wet. I am hoping it will set before the predicted frosts at the weekend.
