Pennyviz
- Wick, BS30
Hi
Have 14th C listed farmhouse with rising damp on some internal walls. The previous owner has laid porcelain tiles over old quarry tiles on kitchen floor of area about 13m2. Situation was made worse by cracked gully outside from kitchen sink, washing machine etc causing water to pass back under external kitchen wall and floor tiles and surface up through walls. Fixing the gully has improved damp considerably but I'm worried that a wet winter will just make things deteriorate again.
The received wisdom seems to be a glasscrete floor but am having problems getting quotes (most builders just want to lay concrete and I have asked Ty Mawr for suggestions) and am getting quotes of about £6K (without underfloor heating or anything fancy), this seems to be an awful lot - or am I being simplistic?
Is the full glasscrete floor the only option or are there other ways to go?
