A
Anonymous
Guest
I just want to raise a few points about limes, in the hope of seeing what your thoughts are.
I have been repointing a rubble cottage recently, partly using lime putty, and partly using bagged hydrated lime. Now, I realise that lime putty is undoubtedly the better material, and if used properly will guarantee good results. However, my experience is that for my purposes, hydrated lime has produced identical-looking and performing mortar to the putty. This is despite me simplifying things to the minimum by mixing it dry with sand and then water rather than soaking first to produce a putty. And hydrated lime is much cheaper than lime putty. It also avoids the problem of sloppy mortar which one tends to get occasionally when putty is used, even when no extra water is added.
I do not use bagged lime for plastering, and I would not use it if I was repointing Windsor Castle. However, I do feel that by insisting on the use of lime putty on all occasions, the conservation movement is sometimes making the best the enemy of the good. My contention is that the average builder, doing the average repointing job, is much more likely to switch from OPC to bagged lime, which is cheap and can be mixed in the same way as cement mortar, than he is to switch to putty, which is expensive, not available at builders merchants, and of alien appearance.
Any thoughts?
Any thoughts?
