Hi and I'd appreciate the panel's advice on a listed building consent issue please.
I have an old stone house which has evolved over the years. The oldest part was probably a simple one up, one down cottage which was extended to cover an old well (I've been advised that the well is medieval). In Victorian times another section was added to house a shop on the ground floor and I'd guess either stockroom or bedroom above. Traces are still evident of where the shop door and large display window were. Nowadays the ground floor room now has two windows:
1) A three casement window with two opening each having eight panes of glass (the general style of this windows matches that in the older parts of the house) and
2) A three casement window which has three, two pane, fanlights (CO refers to them as 'top hoppers') above three fixed casements each housing four panes of glass. This window was fitted at some point in the past into where the display window was with signs that the size of the opening was reduced.
Due to their poor condition both of these windows need to be replaced.
The CO has been very supportive of the renovation work I've undertaken but has surprised me with regards to window (2) above.
Rather than agreeing to my replacing it like for like they have asked me to replace it with one in keeping with the remainder of the house, namely, a three casement window with two opening each having eight panes of glass.
This I find a bit perplexing because I can't see any justification for changing the appearance from what it was at the point of listing and I've already sourced a like for like replacement so am not keen on having to re-engineer this.
Does the panel have any experience of dealing with sweeping away clear historic evidence and replacing it with some sort of what it might have been like please?
Thanks,
Nigel.
Thanks,
Nigel.
