can someone please tell me why i cannot use this , or why i should not use this
http://www.antiquedoorfittings.co.uk/ourshop/prod_112000-VictorianEdwardian-Brass-amp-Ceramic-quotJelly-Mouldquot-Light-Switch.html
and instead use this?
http://www.tlc-direct.co.uk/Products/CS1920R30.html
the problem i have with the latter is the brass used nowadays is more like coated tin foil as opposed to the heavy brass used years ago. i really cannot do the modern , coated , gold type brass used in modern fittings , i want something that will tarnish that i can use polish on and not something coated in a gold coloured lacquer..
what's your views guys? are the original switches safe to use?
