formerly known as
we are renovating a property in the east Anglian region that contains several forms and phases of construction, the oldest being timber frame. The timber frame had been 'faced' in the mid c20th with boe and s+c render to visually correct a lean caused by roof spread - this lean corresponded with an inward deformation of the sole plate. Whilst w+d remained in places, the framed required stud renewal/s, so the w+d had to be removed; I was also keen to introduce a lighter insulation between the original timber frame and a secondary inner timber frame that I have installed so the original frame can 'hang' from it for additional support. After research, I came down on the side of hemp batts for insulation, although the cost of which was making my teeth hurt. So, enter stage left - light clay straw. LCS is basically barley straw coated in clay slip - although we added non hydraulic lime also - the slip being our own reinterpretation of 10pts water, 4pts reconstituted clay from the daub and 2pts lime, all mixed up in a water butt with a paddle mixer. The mixture is then lightly rammed between shutters and then rendered or boarded over. We will be l+p internally, with sweet chestnut feather edge outside. Have a google of light clay straw. Originating in Germany, used latterly and currently in various parts of the world and with a couple of experimental buildings in the uk. with the materials being cheap as chips, this in my opinion is a realistic alternative for an insulative panel infil. Oh, if you try it, wear long indestructible gloves to avoid scratchy straw lime burn :shock:
