Hi,
We are in the process of renovating a Methodist chapel, it was built in 1883.
The floor is suspended and made of pine floorboards that are 38mm thick. The boards have a grove in each edge and a metal strip is inserted to join the boards together. A bit like a metal tongue. We need to lift the floor and relay it.
So, has anyone here tackled a floor like this before? and if so can you offer any advice on how to lift the boards causing the least amount of damage to them?
My current plan is to punch the nails right through into the joists with a metal nail punch then pull the board away from the next and remove the metal strip. I've no idea if this method will work successfully. Any advice you have would be very much welcomed.
Many thanks
Mark
Many thanks
Mark
