I need to lift and relay some original, handmade floor bricks that have started to rock because the lime mortar they were laid on wasn't done properly to begin with back in 2009.
They're close laid with virtually no gaps (<2mm), as they are handmade they are all slightly different and interlock very closely which means the same brick has to go into the same hole in the same orientation.
I can ease most of them out, excavate some of the bed and relay them with fresh mortar or a few others come with them and the whole patch gets relaid.
I have a couple that are rocking but jammed in and the bricks around them are well stuck and I can't shift them either. If left the rockers have a tendency to break which is ugly.
Any ideas how I can get the problem ones out without having to relay the whole lot?
