I have a Victorian terraced house with a bay window at the front on the ground floor. The bay has a parapet round the top and originally a flat roof inside that. There is now a flat zinc roof across the top of the parapet and a gutter all the way round. The roof meets the house wall about 2 inches below the two first floor windows. There’s a zinc apron that covers the join. If you lift up the apron you can see that the upturn on the roof, which should come up about two inches is about ¾ of an inch so the theory is that rainwater is being blown under there. There is damp underneath both windows inside and with heavy rain recently the water dripped through to the room below. If the upturn was higher this shouldn’t happen. So the options I've been given so far are 1) to run mastick along the join – cheap and not reliable I think. 2) to replace the zinc with a higher turn up – but as the space underneath the window ledge is very tight this is quite fiddly. 3) to remove the roof altogether and repoint the wall – this relies on there being a decent roof underneath and a new downpipe also needs to be fitted.
I'm wondering which is the best option and also why the second roof was put on in the first place. About half the houses in the street have this second roof and others are as they were originally. Does anyone have any experience/advice?
