Andre Standing
- Dorset
Hi,
First post...
My wife and I have recently bought an old stone cottage in Dorset. It has been subject to the usual treatment of heavy cement renders and a horrid cement floor--laid directly on earth--which was cracking badly. I am removing the cement renders and have already removed the cement floor in the living room. I wanted some advice on how we are going to redo the floor in that room.
I want to lay the floor with reclaimed flagstones. The floor at the moment is bare earth, which is essentially thick clay. It is a small room - about 10 square meters (with a wood-burning stove).
I want to avoid a limecrete subfloor. I have previously built earthern floors (having built a few cob houses in Kenya), and have laid stone floors directly in earth, which works well. But here I want to improve the insulation and I would love to install underfloor heating. Unfortunately this will have to be electric.
I am thinking of digging down and putting in a layer of compacted geocell aggregate, then a geotextile fabric over that, then covered in sand, upon which I will lay the stones. The stones I have are quite uneven in depth, so I want to lay into a dry mix so I can adjust the heights of each stone. I know this is not a conventional way of doing it, but I see no need for a limecrete screed beneath the stones. What I am wondering is whether it is possible to put electric heat mats under the floor, perhaps embedded in the sand?
Is this a bad idea and do you have suggestions for alternatives?
Many thanks in advance!
First post...
