Hi
I have support in principle from CO to replace modern plasterboard ceilings and expose the loft area above bedrooms. Now I'm just getting ideas for the detail of how I actually plaster up between the rafters.
My challenge is what to do with the purlins. They are just above head height, irregular in shape and are not parallel to the floor. There would be a gap between the rear surface off the purlins and the laths and I wouldn't be able to lath right up behind the purlins. The gap would be less than the width of a lath i.e. 2-4 cm... I am thinking of options such as:
1. Box-in the purlins with a thin frame and lath over the top of it - I'm not sure would look right proportionally and would probably look too straight.
2. I could leave the purlins exposed and place a filler piece i.e. piece of wood behind the purlins (top and bottom) to butt up against the laths - not sure how I'd fix these and I'd like to do something with the least additional nails / screws being used on the historic fabric.
3. I could somehow try and plug the gaps with lime - but not sure this will simply break off over time without support of some kind... perhaps I could use a metal lath/mesh but a mesh would be spoiling my proposed traditional approach.
4. I guess another option would be to position small batons attached to the rafters so that they simply angle out toward the purlin to reduce the gap to a minimum - then I could blend that in with the lime plaster.
Does anyone have exposed purlins in their property? How are they finished with plastering behind them? Any ideas or tips would be welcome - preferable a traditional approach.
Thanks.
Thanks.
