MatthewC
- Central/South England
I'm sure this is not unusual, but I think it is worth publishing the picture. Don't ever assume, just because something is covered with lath and plaster, that it is not load-bearing (viz Kirsty on Location Location).
Our two back bedrooms are separated by a lath and plaster wall, which needed to be re-plastered as the lime plaster was all crazed and had come away from the laths - huge areas moved alarmingly, and some had been patched with modern alternatives. This is the wall structure we uncovered:
Those two X frames which you can see are both made from oak beams, 4 inches by 3 inches. Each X is about 6 feet wide and 8 feet high. At the top of the central stud is a metal bolt, pointing downwards, which has a square head about 1.5 inches across. The laths are in really good condition and even the nails are still shiny, not rusted.
This is a major piece of structure and not just a simple stud wall, although at first its purpose puzzled me. There is no corresponding wall in the kitchen beneath; on the right of the picture is a major internal structural wall, about 18 inches thick, largely of squared limestone, and on the left is the external wall which is about a foot thick, in limestone rubble. After mulling this over whilst going to sleep, finally it dawned on me: I reckon this structure is holding the external wall in place, unless someone has a different idea?
Oh, and at last the roof is done and the scaffolding down - Happy Day! - see blog
Matthew
http://houseintheenchantedforest.blogspot.com/
Matthew
