Hi,
I'm trying to fill a gap approx 2m high by 60cm wide in an interior wall. The original wall is of lath and plaster construction. I know there is a bewildering array of lime-related Q&A on this forum, but that's just the problem, too many topics to sift through. So could the learned folk on this site please indulge me and answer these queries:
1. Does the caveat re working with lime late in the year (i.e. after October or so) apply to interior work? I'm guessing not, but can you confirm.
2. Once I've built my frame of timber struts and laths, what lime do I use? I realise there's hydraulic and non-hydraulic lime, which one do I go for? Whichever one, I'd prefer to use the putty form, as I've tried mixing the dried stuff and nearly choked on the dust.
3. I'm assuming the main mix is something like 1 part lime to 3 parts sand, with some hair thrown in just before getting ready to apply (I've downloaded the article by Bennett from buildingconservation.com, which doesn't however tell me whether to use hydraulic or non-hydraulic lime). But that will be quite heavy. The original plaster seems really lightweight and powdery, with lots of coal flecks in it. Should I reduce the amount of sand and substitute some lighter-weight material? Any suggestions with what material?
4. And what about this 'pozzolanic' I keep reading about? Presumably the coal was the pozzolanic in the original plaster. What do people use these days, if anything?
Many thanks in advance for your advice.
