So nearly there! ready to start repairing the plaster in the end bedroom. I have used a few tonnes of lime putty mix from Mike Wye, just used the last of the bag today. I am reluctant to purchase any more when I have some bagged lime to use up. There is NHL 5 and 3.5 as well as some consolidation mortar. I am familiar with premixed lime putty on the walls, but what should I use if I am to use up the NHL - the 3.5 or the 5. I know the 5 is quite strong and will set hard. Should I continue with the layer system of where applicable, consolidation (crumbly wall so will do), then haired then unhaired then a finer plaster finish?
What mix would I use for the walls? 3 sand 1 lime or the same as we used for the floor which was 2 sand and 1 lime?
Advice welcome.
Advice welcome.
