A
Anonymous
Guest
There are quite large gaps between most of the panels in a Victorian front door. If anything the gaps seem to be getting larger and the door is warping quite badly at the bottom at one side.
The door seems to be a fairly unique 5 panel design and all but one of the neighbouring properties have identical originals - that look in much better condition !
After stripping some paint back I'm pretty such it is pine. Although there are a few layers of paint I am starting to suspect it has been dipped in the past like all the internal pine doors - which also seem to be getting increasingly warped.
Should I even consider trying to dismantle the door into the original sections and fixing back together - without gaps.
Or is it unlikely this wood be successful ?
If I have to fill the gaps what would be most suitable - would a linseed putty for example be likely to stay in situ in daily use.
