88v8
- Glorious Gloucs
Our cottage was built into a slope, usual problem with damp walls.
Going to lower the ground level along the back, and install a land drain along the drip line. Flexible 4" perforated plastic in a 12" trench, laid and surrounded by pea shingle. Drystone retaining wall.
For most of the run, there will be no soil over the top, but inevitably leaves will drop in the trench. To prevent the drain from blocking over time, I'm inclined to wrap the pipe in a layer of Geocel or Terram, plus a further layer of textile over the top before putting on the final layer of shingle. Is this too much textile, will it overly inhibit water movement into the drain?
Don't want it blocking up, but not much use if the water can't get in in the first place.
For the final part of the run, not alongside the cottage, there will be plants on top, and here I intend to wrap the pipe in dpm to prevent it from blocking and also prevent it from absorbing water.
Ivor
Ivor
