vicky whitworth
- East Devon
Yet again I'm after some advice. The floor joists above our scullery were described as 'beyond saving' on our strucutural survey and since then a structural engineer has said that we shouldn't be walking into the room above as the whole lot is likely to collapse. Mind you that was two years ago and my 16 stone OH uses the room every day but there is certainly a lot of movement in the floor (it makes me feel slightly sea sick to walk over it) and downstairs in the scullery where the joists are exposed we can see that they are 1) riddled with old worm holes 2) broken in places 3) do not reach the walls on either side. There has been a bit of patching over the years but to be honest the 1x1 bits of timber someone has screwed up are a bit pathetic. The room above used to be a hayloft and we suspect that the joists have rotted from having damp hay on them. We think the floor joists date to about 1800 but it could be a bit earlier. The timbers are weedy abaout 3x4.
We have a builder scheduled to replace the whole lot - new joists, new ceiling (currently ceiling is made up of something I think is called fibre board - nice!) but I would like to try to save as much of the timber as possible - possibly by scarfing (!) new timber into the ends of the old ones (although I'm not sure there is even sufficient solid timber to do this).
Has anyone had any similar experience or could recommend anything? Many thanks, Vicky
