As the boss has decided we needed a new kitchen and I have agreed everything is straightforward, as much as it can be, except the extract from the hob.
The old hob just recirculated, I do not like these. So where to run the ducting. It just so happens there is an old chimney stack in the kitchen which surprisingly has two 100mm
soil pipes running up it. One is the vent for the downstairs wc fan and the other just ran to ground level in one of the old cupboards and terminated with a plastic vent, most odd.
So my question is would this second soil pipe be suitable to carry the extract from a hob considering it has to go around 3m horizontal then 2 floors plus the stack on top, around 7m
vertically. As far as I can see both these soil pipes are terminated in some sort of mushroom shaped cowl where the exit the stack.
Venting out through the walls is possible but more more work entailed than going skywards up the chimney.
