plasticpigeon
- Birmingham
Hello people
I am hoping someone can tell me what I have here. I am removing (or hoping to remove) an old Parkray from a kitchen chimney breast an an Edwardian terrace. It is a large opening which I imagine once had a range in it. I was expecting to find a metal flue liner attached to the Parkray. Instead I found some brickwork forming a small flue from the top of the back boiler. This extends up the main flue a few feet above the top of the opening. The walls of the flue were built into the brickwork at the front of the opening which I have removed. however neither the bricks at the front or the bricks dividing up the main flue go all the way to the floor. they seem to be suspended somehow. I can look through the gap to the right hand side of the parkray and can see the backboiler with pipes coming out of it. It does however have some kind of concrete box around it, and I can only imagine that the brickwork above is built onto that. I don't really understand how the small flue was built as it goes up quite high and is very narrow. Anyway, to get the Parkray out I imagine is have to take this small flue out, but where do I start from?? I can't take it out from the top down as I can't get to the upper bricks, but I am scared just to start from the middle as I don't want the lot to fall on my head!!! Does anyone have any advice>>
Many thanks
Jerome
Many thanks
Jerome
