fernicarry
- Argyllshire
I have a few joist ends that are rotted out and not taking any load into the wall that need repair.
The inner front door is about 18" from the end of the joists and its frame is now taking the load of 2 of the joists, without any particular sign of distress I should add. The third may be resting on top of the internal wall between the hallway and the front room but also no obvious sign of movement above or below. These joists are quite short as they only go to the top of the stairs so really aren't carrying very much.
So far I've sistered one, which conveniently has a much wider pocket in the wall than it needs so that made life easier. I jacked the end of the old joist to get it just clear of the door frame, bolted on the new joist and bedded it into mortar in the pocket. The hope is that when I let the jack off that it won't drop back onto the door frame, or at least less heavily than before. How long should I give the mortar to harden up? Its NHL3.5.
I'm not sure what to do with the other two. The front hallway has a very nice cornice so cutting back any further than the front door is not an option I'm willing to get into. That leaves me with a bit less than 18" to play with from below. Have plenty of access from above as I've lifted the floor boards. Wall is stone rubble construction so making the other 2 pockets wider not likely to be straightforward.
I'm thinking possibly putting dwangs between the joists and resin anchoring those into the front wall then hanging new joist ends on them and bolting onto the existing joists. The inner leaf of the wall is quite loose though so not sure how much of a purchase I can get.
Any other cunning ideas on this?
