A
Anonymous
Guest
Hello everyone
I am in the process of renovating my house which dates from around 1830. The walls are around 2'6" thick and are constructed from random sandstone.
I am currently in the process of removing the gypsum plaster to the living room walls on the ground floor, my intention being on the gable wall to simply repoint any bits that need it with a hydraulic lime and leave it at that. Once the plaster was removed I was suprised at how quicky the walls seemed to dry out.
I've found the original fireplace on this wall which is about 3' x 4' in size and I want to use this for a proper fire (see cracked sanstone lintel thread). I think that the flue is in pretty good condition because when I pulled the old gas fire flue liner out nothing came down apart from a bit of soot. There are 4 stacks (separate) on the roof and 4 fireplaces in this wall (bedrooms etc), however I've found the set-pot in what will have been the old kitchen a few metres away from the large fireplace. I want to open this up and make a feature from it. My question is will the flue from the set-pot join the main fire's flue somewhere? and if so would it be sufficient to close off its flue just above the lintel with rockwool and plasterboard providing that a smoke test on the main flue is okay? Or would I need to consider a flue liner?
Any ideas or advice appreciated.
The main fire's flue will of course be swept before I use it.
