biffvernon
- Lincolnshire
European Strawbale Duilding forum said:Hi there,
I have built my Straw Bale home & moved in last June.
The house is amazing and we are very happy.
Since we have moved in I noticed there are these small bugs that you see once in a while tiny ones, can hardly be seen, and usually in groups. I have looked these last few days on the net and am quite sure now that they are "straw itch mite", does anyone know anything about this mite? the effect it might have on the bales etc...? any info will be appreciated.
Regard,
Amit
Dear Amit,
They probably are what we call plaster beatles. They live on the fungus
that is created behind the plaster. When the plaster dries they stop as
there is no more moisture for the fungus. If they keep on coming out of
your wall for more than 2 months you probably have a moisture problem in
your wall (and should say 'thank you' to the beatles for letting you
know). For now the thing to do is to vacume often. They are not harmful.
Look where they come out and fill up those holes (once all is over)
because these spots are air leaks (and say 'thank you' again). Also
check if there is a certain wall/area is affected as it might be a
moisture problem.
Best regards,
André de Bouter
La Maison en Paille
