Andys
- At the seaside in Hampshire
This is our back door, on a '90s extension so not strictly a period question. The door sill and the bottoms of the side pillars have rotted because they're sitting at ground level.
Having removed the sill, the strip of damp course and the packing slices of brick, I can see the concrete foundations of the house and the base of the outside path. Between the two there is a great big slot about 9 inches deep - is this normal, some kind of isolation between the two, or is it a massive hole waiting to be filled with rainwater?
Do I fill it or leave it and cover it as before? I wouldn't want to lose the cat down it.
I'm inserting fixings through the door posts into the brickwork for stability and thinking of laying a brick sill which can take the dampness.
Edited to add: ah yes, no, the slot is actually between the block foundations for the outer brick skin and more block foundations for the inner blockwork so it's an extension of the cavity. As it's all well below the damp course in the outer brickwork I could fill it with some sort of pouring concrete, no? What troubles me is the way it looks so easy for water to run off the outside path, right down this gap.
