plasticpigeon
- Birmingham
Today I have been grinding/chiseling mortar out of a section of wall in order to repoint. I am hoping my pointing is up to scratch now. Some of the wall had rock hard cement in it, and other bits had some NHL 3.5 pointing that I did last year. This pointing wasn't the best as I was (and still am) learning. I am taking it all out to do it again. Unsurprisingly the cement was hard to get out. The best method I found was to grind a channel down the middle and try and lightly tap the edges where it adhered to the brick. The method works ok for the most part. More surprising to me was how hard the NHL mortar had got. When grinding there was almost no resistance, but when chiseling I found that it was about as easy to gouge out the mortar as to gouge a brick, meaning that the NHL mortar was about as hard as my bricks. Although not as brittle as cement, in places it did crack rather than crumble. The original lime is very much weaker. I hate to admit this, but Andrew Bodenham did warn me of this in a post a few months back!!!!
I think I want to modify my mortar mix, but what to? I was using standard 3 sand 1 NHL, but I was thinking that 2 possibilities are 4 sand to 1NHL, or even 1 NHL, 1 hydrated lime and 6 sand a bit like 1:1:6 mortar except using NHL instead of cement. I'd be grateful if anyone has tried this or has any ideas.
P.S. I know I could use putty but it is not available near me, and I appreciate the faster set of NHL.
