Roger H
- Northumberland
I've a ground floor kitchen that is sunken into the ground at one end. The walls are a double skin of sandstone with a rubble fill. They are pointed with lime inside and out after I'd ripped out the old cement. Prior to this, they had been poorly dry-lined with plastic sheeting and hard board. On removal of this, and of the internal cement, water literally gushed from the wall.
I fitted a land-drain outside and lime washed inside with a mix of 50% hydrated lime putty 50% water with a glug of linseed oil.
The walls are now dry to the touch but I suspect are cold bridges as there are occasional black mould points on them. In general, I think I've done all I can to dry out the wall but am wondering what can be done to tackle the mould. I fear that more limewash with oil will just be feeding it? Would an oil-free limewash work or is there something I can add to the lime (salt?) to make it a less comfortable environment for them.
Any advice appreciated, Roger
