Hi, another damp question I’m afraid. I’ve done some research here but still trying to decide the best avenue to go down so wondering if anyone here might be able to advise.
I have recently moved into a lower and raised ground floor flat, which forms part of a mid terrace 5 storey Victorian house (1880s). When I purchased it I was aware there was a damp problem which the vendor had got an estimate for of £8k and I ended up negotiating to take it off him and do the work myself once I’d had the survey.
Basically the extent of the damp is on the lower ground floor on a number of the walls. The paint has peeled off in certain parts of some of the walls, sometimes along the bottom (where there’s a bit of mould in a couple of places), other times much higher up towards the top and middle….so at fairly irregular places.
I’ve had two firms round so far. The first suggested the lower bits of damp were due to rising damp (hence replaster + damp proof course) and also to penetrating damp for some of the higher bits (he recommended replastering with a specialist waterproof plaster here – tanking). The second said that it was all due to hygroscopic salts in the bricks (from rising damp and water pushing up from the ground in some cases where the lower plaster was better and then coming out as dampness higher up when the plaster wasn’t as good) and suggested damp proof course + replastering of affected areas + replastering of many of the unaffected walls (at least no problem to the naked eye).
I’m quite sceptical of both as they both just went along with a damp proof meter and I’m concerned that they may be replastering stuff they don’t need to. Not sure if anyone here has had a similar pattern of dampness before?
So would it be my best bet to get an independent specialist report who wouldn’t be doing the work hence no reason for them to recommend unnecessary works? The surveyor recommended Specialist Xpress (they charge £150) – anyone heard of these or got anyone else to recommend?
And once I’ve got this report has anyone got any good recommendations for damp proofing firms?
Thanks (and apologies for the length of the post!)
