jungle_jim01
- Loftus, North Yorkshire
Hi, as you may have gathered from my other posts i'm in the process of repointing. For a while now, i've pondered over some cut down iron bars protruding from between the stones. (photo attached) I had wondered if it was part of an old downpipe. They run in straight line most of the way down the building from roof height, but i cant see any in the lower couple of meters (may have been removed already). On removing the pointing I can see these are well bedded and wedged in with wood. I'm wondering if i can remove them or if there may be some structural reason not to? Also...any thoughts on if i should remove them from a preservation perspective?
Any comments would be welcome.
