Claudatious
- Brighton
Hi there,
I live in a terrace house with a solid front and rear elevation made almost entirely of Bungaroosh (lime, flint etc). Im trying to get my head around the many different approaches to insulating internally. The Bristolian guide to solid wall insulation (https://sdfoundation.org.uk/wp-content/uploads/2018/01/2015_bristolsolidwallinsulationguidance.pdf) suggests not exceeding 60mm in depth of insulation so to allow some amount of warmth to the solid wall to allow for moisture dispersion. Additionally, many of the suggested methods require a lime render finish on the internal final finish, which to be honest, is a bit specialist and hard to get my head round.
Ive come up with my own idea! which I am asking your good selves if you would consider and scrutinise. My idea is to use either flexible hemp or flexible wood fibre insulation laid against the internal wall horizontally held against the wall with a 3x2 stud wall. The insulation side of the stud timbers could be wrapped in foil tape to prevent contact with any amount of moisture content within the insulation. Vertically in-between the stud timbers I would leave empty and use this void for electrical points. Then final finish would be plasterboard and gypsum plaster. To allow the wall to breathe I would insert round vents (approx 30mm diameter) in-between every vertical stud, both close to floor level and ceiling level.
Can anyone think of why this idea is floored? It seems sound to me!
