Weighing up which approach to take to finishing a couple of walls upstairs so after some opinions which I know you lovely people will have
To jog the memory as I tend not to post much, its a C18 farmhouse that was obliterated with cement and uPVC in the '80s. We have spent 10 years as and when able removing said cement and uPVC and replacing with lime and timber :lol: Doing so has gradually restored the building removing damp, repairing decaying brickwork etc - you all know the story.
Anyway, we are now doing some work upstairs and have removed yet more cement render (1" thick) which was then covered with plaster and plasterboard to reveal the original brick smothered in bituminous paint :roll:
The walls are 9" solid brick and I have to decide how to finish them. They are both outside walls, and the other two walls are cement render/plaster (internal solid wall) and plasterboard (internal partition) (Tried to add a pic but not been succesfull so far
As I see it I have two options which I would like some opinions on:
1. Lime plaster as I have downstairs. Issues being will the lime plaster take to the bitumen covered bricks? I will try to remove this but not hopeful. If I do lime plaster I will have two walls in lime and two not so paint match is going to be interesting..... The lime plaster won't insulate much but will breath although being first floor these walls have no damp issues. Also, the ceilings were quite low so the wall plate is at the height the bricks stop in this pic. Above that has been covered by plasterboard infil to the ceiling so lime wouldn't work there unless i lay it on some wood wool board or similar.
2.Dry line wall with 25mm batten followed by space blanket type insulation similar to this http://www.ybsinsulation.com/roof-insulation/pitched-roof-insulation/superquilt-pitch-roof/ followed by 25mm batten with plasterboard fixed to it. Advantages are it gives me some insulation and a consistent finish to the inside of the room. Disadvantage is the risk of the external wall not breathing and interstatial condensation. My thought process is the Superquilt will act as a vapour barrier if taped properly so I can minimise air leaks into the external cavity and I could leave gaps for air flow from this cavity into the roof space. As this wall is quite dry anyway I am not concerned with it having to dry out etc but I don't want to create any new problems.
So there ya go, thats todays essay - any thoughts?
Cheers,
MM
Cheers,
MM
