Dampadoodle
Hi,
We've converted the loft of our Victorian semi and I've prepared a lovely section of brick work to remain beautifully exposed. This will be about 4 square metres in the far corner of the room. The bricks are tatty and full of character. We're going to stick a renovated old Victorian radiator in front of it. Ideal Classic I believe. Very exciting. Anyway, I digress.
I'm now ready to do the repointing and I obviously want to use some sort of lime, not any of that (get ready to hisssss) cement based mortar...booooooo to that!
So now I need to decide exactly what type of lime mortar to use. The variables are:
- Colour
- Coarseness of aggregate
- Use of a Natural* Hydraulic Lime (e.g. NHL 2 or NHL 3.5 or NHL 5) or use a lime putty based mortar (e.g. Coarse Stuff) (*Edited - previously wrongly read "Non-Hydraulic Lime" - thanks for the advice, Roger! - see post below)
- How to finish off the mortar (flush, non-flush etc)
The bricks are a heady mix of red and yellows and many between the two - so chalk white may be too strong in terms of colour contrast. I think I'll go oatmeal.
As for the type of mortar I've called lots of suppliers and they all differ in their advice. Some say putty (although this takes a long time to go hard) and others state categorically that it should be NHL 2 and nothing else. Apparently it all looks the same when dry. I'm looking for something premixed and dead easy to use.
I'm a novice with a pointing trowel if that helps you to help me.
I'd love to hear your thoughts regarding all the above. And, no, I will not "get someone in to do it" a) because I want the pleasure b) because most contractors just want to shove in cement c) because I like a challenge d) because its cheaper!
Over to you & thanks in advance,
Dampadoodle.
- Colour
Dampadoodle.
