JohnB
- Beautiful sunny West Wales!
The gypsum plaster skim on part of the room I'm working on was loose, so I ended up removing it, then the half inch of softish cement, then the rock hard almost pure cement, to find out what's underneath, and found this:
The vertical line was clearly on old window opening, and still has its lime plaster, tiny traces of red limewash, and a few bits of wallpaper. It's been filled in quite roughly with cement mortar, while the rest of the wall has earth mortar with lime pointing. For a mid 19th century house, it appears to have been a big window. The house is shown on the local woollen industry information boards as having had a hand loom workshop, so I'm wondering if this is where the loom was. The house is listed in the 1891 census as one house, but in later years was two, so I'm thinking this part may have been built as a workshop, and was converted to a house when the residents gave up the weaving.
As you can see, there is part of a timber lintel, and the top of the current window is higher. The beams have been stepped, and sit on a concrete lintel resting on the original lintel. Here's a close up, showing where the lintel was cut. There appears to be traces of old wallpaper on the underside of the lintel, so presumably it was originally exposed.
Here's a view of the end of it, showing the rot! Even with my poor sense of smell, I noticed it as soon as it was uncovered. The beam that rests on it is also rotting at the end, and the next beam along (in the corner of the room) that rests on stone, is also rotting at the end.
Any suggestions what I should/could do? I could do with a safe but short term fix for a year or two, as I don't want to deal with all the walls in the room at the moment.
