joatex
- Woodstock, Oxon
The farmhouse (not listed) has had a large extension added more than a hundred years ago. The tiled roofing has a considerable slope and the inner surface lined with lath and lime mortar plaster. I wish to provide insulation for this large area. There is no access apart from lifting and relaying the tiles or breaking through the fragile lath/plaster. In the latter case it would be difficult to make sure that ventilation was adequate even if insulating boards could be inserted without damage due to the irregular surface of the laths. The state of the rafters is unknown without lifting tiles but the roof shows no sagging.
The previous owner of my own house (circa 1970) has lined the inner surfaces of the outer walls with polystyrene sheeting apprximately 3/8th thick, then papered those with artex. Prone to damage but effective. Is polystyrene sheeting/boards a 'no-no' these days? If not, such sheets (or similar) could be stuck to the plastered ceiling of the extension then covered with lining paper and a breathable paint applied.
